Use this procedure to view the port-based shaper information. The system displays the port, egress rate limit in Kbps, and the rate limit status.
  1. Enter Privileged EXEC mode:
    enable
  2. View the ingress port-rate limit information:
    show qos shaper interface gigabitEthernet [{sub-port]][,...][slot/all][all]}]
Switch:1#show qos shaper interface gigabitEthernet 1/1
                        Port Egress Rate-Limiting(Shape)
PORT    EGRESS RATE-LIMIT(kbps)    ENABLED/DISABLED
1/1     0                          DISABLED
